Disables PIM on a router interface.
ipv4 | Specifies the IPv4 address family. |
ipv6 | Specifies the IPv6 address family. |
vlanname | Specifies a VLAN name. |
all | Specifies all VLANs. |
N/A.
Use this command to disable PIM for a specific or all VLANs.
The following example disables PIM on VLAN accounting:
configure pim delete vlan accounting
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.1.1 Licensing Guide document.
